I have two question abot the gallery.
1.) How can I deactivate “All” in the gallery-filter? I don’t need it on my website because it doesn’t make sense. I want to show another filter-category first when visiting my gallery site.
2.) How can I delete the social media icons in the lightbox of the gallery?
Could you please help me?
Thanks.
To disable social icons do same thing like in superior theme http://support.apollo13.eu/discussion/comment/6040#Comment_6040 and change all that values to
falseAbout filter - it is not easy to deactivate "All" as it is used to preload some items. Can you explain why "it doesn’t make sense" in your case? Maybe then I could come up with some solution.
thanks for your answer.
I will try to explain you why the gallery filter doesn't make sense in my case.
The gallery filter is used to show products which are categorized into three main-categories. Those three categories contain another three categories which are all the same in every main category.
Here is an example to make it easier to understand (I hope so
Main Category 1 contains Category 1, Category 2, Category 3
Main Category 2 contains Category 1, Category 2, Category 3
Main Category 3 contains Category 1, Category 2, Category 3
You can also visit my website, maybe it could help you: www.helbling.vms-design.de
With Regards.
If you have three main categories of galleries(in you case products) why not link these there main categories from menu separately ? You do it same way as with multiple works list http://apollo13.eu/docs/blame/#!/adding_multiple_works_list_and_genres
Without "All", use of" All galleries list template" is rather useless.
Hope this will bring us closer to solution :-)
