Our site is at:
http://highgate.mammoth-hosting.com/I have 2 requests:
1) We are seeing a white page before each page loads, when clicking on menu link. Tried turning preloader on and off and still happens. How do we remove this white page or make it black so less noticeable.
2) How do we remove the ‘hide preloader’ text under the preloader
1. This is not AJAX theme, so there have to be "blank" moments between pages load. You could do some optimizations to site default styles, to serve CSS with all HTML as fast as possible, but this is huge topic, and you will need for this someone who has some experience with serving "above the fold" page in less then 1s. Then you could almost not see "white screen". It also depends on server speed.
2. I wouldn't recommend doing this, as preloader may stuck in some edge cases, and thanks to this link your user still can turn off preloader, and operate with your site.
But you can do it with such custom CSS:
.skip-preloader{With regards.display: none !important;
Could you please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach link to topic it applies to.
