Hi!
The following problem occured on my site: when you place "people" widget on one page with other widget like "recent posts" or "post grid", then arrows in "people" stop showing. Also all "people" slides appear at once.
You can see it at the main page of
http://kuchniawogrodzie.eu/"People" works fine on a sub-page "Partnerzy":
http://kuchniawogrodzie.eu/strona-glowna/partnerzy/I would really appreciate if you could help me.
Kind regards,
Hanna
it turned out, that the Visual Composer plugin (which is essential for our theme) started to use the beta (not stable) version of OwlCarousel2 plugin.
We on the other hand have included stable version (1.3.3) of OwlCarousel, and apparently there's a conflict between those two scripts.
We need to investigate the situation, check the quality of the script that is included by Visual Composer, whether we can use it instead of one included by us.
For now - please don't use non of these four shortcodes: 'Media Grid', 'Post Grid','Masonry Media Grid', 'Post Masonry Grid', these are prepared by Visual Composer.
Instead You can use 'Image gallery', 'Image carousel', 'Latest Posts' and 'Latest Works' which are prepared by us.
Anyway: thank You for the report, we'll fix that in upcoming update.
Thank you for the prompt response. Unfortunately it seems that 'Recent posts' also cause the problem (and its exactly the shortcode I need...)
I also checked 'Image carousel' and 'Latest Works' - all works fine, but don't fit my needs in this case
Kind regards,
Hanna
is it possible to take a look at the page design? I would need an access to admin panel.
If You have nothing against - please send me login credentials via private message.
