Hypershot uses Supersized pluging that has been modified. I want my images to be "Always Fill Screen", so there is not any empty space on the screen, even if that cost the image so be cut off at every single side. I want to have FULL SCREEN no matter the size or the resolution of the view_ing device is. The very last option "Always fill screen" is missing from Hypershot and instead there is another one added that is useless "Fit when needed". I want the exact oposite of "Fit always". Also, why no matter the height I dont have this problem, but if I narrow my browser windows left or right I get this ugly empy space "red in this case". Can you fix this or give me a workaorund or let me know where to change it in the code, so it works as the original "Always fill Screen" option. Thanks
Regards,
Alex
Hypershot was constructed this way(old school times) that you should upload images in only one orientation and then you will achieve what you want. So if you upload vertical photos(higher then wider) and select option "Fit Landscape" then you will get what you want(but not what it was designed for). Same but opposite ;-) with horizontal photos and "Fit Portrait".
Why "fit always" doesn't work? It works but our users always wanted to photos to NOT be cut, but fully visible all the time. So if you upload different orientation photos and use this, then images would be always visible.
So you want from this silder something very different from what it was designed to. AND Supersized originally works exactly the same way, but it doesn't have option "Fit when needed" that never stretches photo to be bigger then original(very demanded option).
Alex
As I said in other topic -we are not using supersized but our own script.
I gave you answer how to get effect that you want - isn't that enough ? :-) As for last six months we are working on successor of Hypershot, so we are totally engaged. But after new theme is done, we can talk about it :-)
Alex
Nothing else is new, only this feature:-)
When it will be available you will get notice in admin Panel and then you can update it as explained here http://apollo13.eu/docs/hypershot/#!/installation_update_update_theme
Alex
Update should be available in few hours on ThemeForest. You will get notification in your Worpdress Panel about it.
Alex
You can see how it works on our front page of demo http://hypershot.apollo13.kinsta.com/
I've downloaded the latest version as you suggested. I put the "zooming" transition but somehow it does not look very well. It very jerky and shaking almost the screen. It’s very very saddle too. Also, it is only repeating "zoom in". Not to be annoying, but please take a look at this here:
http://www.gt3themes.com/wordpress-themes/frame/kenburns-gallery/
It is much smoother, prominent and it changes from transition to transition. It’s a bit more visible, moves around, zoom in or zoom out so it looks more natural and pleasing.
I sure do appreciate your help and support. But I had to state the obvious. Thank again and sorry for any troubles.
Alex
Alex
Alex
1. faster zooming(you wont see shaking then)
2. "Zoom out" and "zoom in" in random sequence, or just one after another.
3. Shift while doing effect.
I think 1. should be stable time, but 2 & 3 random. We will see how it goes. I will try to fix something today or tomorrow and I'll give you preview before releasing next update.
So we will try again until we will be both happy :-)
One idea, is to match the "zoom/shift" effect with the "loading next photo". If that makes sense... Also, when fading from one photo to another, and not just simply replacing it
Alex
I have spend some time on this, but I thinks we are much closer now to good result.
I have added much of randomness to start and end points of animation.
One thing that I noticed that it sometimes stays only in one part of photo, but it only happens in case of specific photos.
BUT I would rather you take a look at it:-)
1. Unpack file from attached ZIP archive.
2. Upload this file to hypershot\js\album-view-full.js
3. Remember to clear your cache in browser to see new effect. To do it use combination ctrl +f5 while viewing album with zooming effect.
Waiting for your response :-)
IS it possible to add “fade” from photo to photo at the end of the transition? Like the example above? Otherwise I am happy with it. Cant seem to find any real problem right now
Alex
About fade - there is fade! Be sure you have set long enough time for Transition speed(ms) in Albums->Single album appearance(Full theme) options.
You are only guy interested in this topic(and me of course :-) ) So we will have to test it together :-)
Remember to clear cache:-)
