I've noticed that my logo and title are not aligned on the left when the browser is in full size. But it is working good while the browser window is reduced. You can test with the following page to better see the behavior change between these two modes:
http://nomadnocry.com/album/angkor-what/I wish them to be always aligned left, removing the blank space currently on full window mode. How could this be achieved?
Thanks for your support,
Charles
.top-menu{With kind regards.float: left;
Sorry if I wasn't clear enough. I just want the logo and the title of the Album to be aligned left without a blank space. Today there is a blank on the left that doesn't appear when the window is reduced. Also fine on mobile but looks strange on PCs when browser's window is in full size.
Charles
I am sorry, for some reason I though you talked about menu:-S
Currently it looks fine aligned (desktop 1920x1080):
You write about "browser is in full size" but I assume you mean setting "Layout style" to "wide"?
If yes then use this custom CSS
.info-bar .inside{With kind regards.max-width: none;
