I've been trying to find a solution on some other discussion before opening this new one, but I have not found anything (or I wasn't able to find any).
I have a problem I had some years ago with html and dreamweaver website... when clicking on a picture a sort of border around the pic or in some objet close to it .. It happens when you click on the pic and then move the cursor in some other place.
Last time I put the css a { display: none} and the border disappeared. This time it stays still there.
Website is www.italiaamoremio.it ... Any solutions?
Regards
Could you post screen shot of it? However you probably mean
outline.Try this custom CSS answer http://stackoverflow.com/questions/814366/how-can-i-remove-the-outline-around-hyperlinks-images#answer-4994554
Only this css will fix it..
a {outline : none;}
a img {outline : none;}
img {border : 0;}
:active, :focus { outline: none; -moz-outline-style: none; }
