Responsive for Iphone
in Fame Posts: 6
The display of the sub-menu on IPHONE screen is not on the full size where the menu is fine. See pictures.
Can you advise how to solve it.
Many thanks
    Please post live link, as there might be some strange block appearing.
  • www.matthieuaime.com here is the link. Please note that menu is well displayed but not the sub-menu (for ex: "PRET A PORTER" ok but not "tenues habillees" and others.
    What code modifications have you done, cause I see that some styles don't kick in and that is why you see this issue?
  • Hello, code was not modified.
    Thanks.
    Then try deactivating plugins that you have installed, and check which one will help. Currently for example you have . in layout after body tag what pushes layout down. You might have other issues that prevent styles form working.
