Hi, On the front page and blog page i would like to change to replace the slash of the date by a"." where i can do that? And second need, i would like to replace the word "comments" by an icon? Thanks
For the last request, when i change code, i get this "Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ',' or ';' in /homez.527/alexisbo/www/wp-content/themes/airlock/loop.php on line 39"
To change / in sidebar you have to edit file airlock/advance/widgets.php find there every occurrence of
$apollo13->posted_on('d.m.Y'); ?><span>/</span>and change slash in To change it in blog list, edit file airlock/loop.php and do same as above change but in: For making icon you will have to change same files but this time replace with image of your icon. For example replace above code with and put youricon.png in airlock/common/gfxWith regards.
2. Link where does it not work(maybe you missed some occurrence of code, check again).
Thank you
Insert
.afterTPL_GFX
