I even tried with
@media only screen and (max-device-width: 1024px) {
#mobile-menu-opener {
display: none;
But I can't get my hamburger menu to stop displaying, and only menu overlay to be displayed.
.icon-menu.tool {
display: none;
Please add it again in custom CSS, and if it will not work I will help you investigate why it doesn't work.
Thanks for your reply.
I've added the code and cleared the cache. Still no change.
Thanks,
Anja
Use
#header-tools #mobile-menu-openerinstead of only
#mobile-menu-opener.With kind regards.
It's still showing two hamburger menus when I go through customise (and select mobile preview) but when I go to my actual phone and test it there it's working fine. I suppose it's just a customiser caching problem which is fine. I don't mind about that.
Thanks so much.
Regards,
Anja
I am glad it worked for you :-)
