Hi there,
I have a question regarding one page navigation pointers. I have added them to my menu and it works, but when I click on certain menu-items, it goes to the middle of my row, but I want it to go to the 'custom heading' of the row. (= the top of the row instead of the middle) Can I set up the specific place in the row where the navigiation pointer points to?
Thx for the info and help!
Anneleen
Could you show up how you got it now? Link to your site? Cause it shouldn't be middle of the row but top of it.
(I have just put a lot of empty spaces in the rows to make the navigation pointer point to the content, but that's probably not the way to do this ;-)
Yes, you're right you need to add empty spaces (paddings) because the top header (logo and menu) is big and cover most of the content.
It works in that way because the ROW will always be scrolled to the TOP edge of the browser and not the bottom edge of the header with menu (i hope you understand?
There is no easy solution here when you have the big header. So what can we do to make it look better?
1) Add the empty spaces (just like you did it)
2) Change the header variant to something smaller like the "One line, Logo Centered" http://nimb.ws/V4XtQC or any other variant.
3) Change the sticky header version to "Hiding when scrolling" http://nimb.ws/Sa4Q90 . It will always hide the header when you scroll down and show it when you scroll up.
Let me know what you think about it
With Regards
Another tiny question, I want to remove the 'linkedin button' in the header, but if I disable 'social icons' in 'customize', it doesn't want to save. It's like a glitch in the program
