Hi! I want to have in Portfolio page (filter "on") images with the same grid as in album "Fullwidth". Not an albums in Portfolio and images in this album. I think you understand what I want to do)
Please tell me: 1. Do you need instructions how to create "Albums list" or "Single Album" in Bricks/masonry mode? 2. You wan there to have filter, right? 3. Could you show me what you have achieved already?
I have photos, which I don't want insert into albums. I want to create masonry gallery with filter above. If I click on photo - I don't want to enter the album.
If this page should only be gallery then you can create album but not show it on Albums list.
So create album as usual and in Album details -> Albums list -> Exclude from Albums list page set to on. You can still add this Album/gallery to main menu and name it "Gallery" or as you wish .
Ok! But what about a filter?) Because I see that there is no filters inside album. There is filter for albums, but no for the photos inside it)
I really need this filter)
And another one question, if you do not mind) How can I change the position of content just for mobile device? I'm satisfied with it on desktop, but want make some changes for mobile. I see that there is an adaptive settings in wpbakery, but this is not the option I need. In Elementor, for example, it is possible...
rb91u said: How can I change the position of content just for mobile device? I'm satisfied with it on desktop, but want make some changes for mobile. I see that there is an adaptive settings in wpbakery, but this is not the option I need. In Elementor, for example, it is possible...
If you could make new topic for this, I will ask Daniel to give his experience about it, as he knows all Visual Editors best :-)
If i understand you right you want to have 1 column only that takes full width.
In this case go to Appearance → Customize → Albums Settings → Albums list → Bricks columns and set it to 1.
Hope that helps.
I want masonry grid (attached) and the category filter (all, portrait, wedding etc.) above!
Please tell me:
To create "Albums list" page please follow this http://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/adding-albums-list/
Next you can adjust options of it in http://rifetheme.com/apollo13-framework/docs/customizing-the-theme/albums-settings/albums-list/
To have filter you need to have albums with added categories. Those categories will be used for filter.
To create "single album" please follow http://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/adding-new-album/
Next add images/videos to album: http://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-media/
While adding media you can add Tags - they will be used to create filter for your single album.
To make albums in bricks/masonry mode you have to set in Album details -> Album media-> Present media in select Bricks http://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-options/
Hope that helps.
Sorry)
However if you want to add this "gallery" as part of other page, then currently this is not possible in bricks mode. You can add "gallery" with slider or scroller shortcodes http://rifetheme.com/apollo13-framework/docs/content-management/shortcodes/
Unfortunately shortcode for bricks mode is not ready yet, but it is high on my TO DO list :-)
But now, I don't know how to change the url of this album..
Now it's: .../album/photo
I need: .../portfolio/photo
How can I do it?)
Why?
**sorry
just need to refresh permalinks
