When you click on 'Submit Form' the URL goes to: http://anamatias.nfshost.com/contact/ (I think this is the old URL when I was working on wordpress in 'offline' mode.)
As I mentioned in private message you have different values in Settings->General in WordPress Address (URL) and Site Address (URL). This is start of the problem as I suppose as I never tested setting this two different, but now is the highest time:-)
First of all, thank you SO MUCH for all your support and quick answers! Everything went well with those codes, the contact form and 'back to portfolio' are working just perfect!
Tell me something, now I've to be very carefully when doing the theme updates right?
In advance/apollo13.php line ~1464 there is And this can cause issue
Change ALL above code to
' . home_url() . $_SERVER["REQUEST_URI"]and check does it help.
As for portfolio page you have mentioned earlier it might be same thing so please try
In advance/apollo13.php line ~1753 there is
if( defined( 'PORTFOLIO_PAGE' ) && PORTFOLIO_PAGE ){change to$href = site_url() . '?page_id=' . $this->get_option( 'portfolio_options', 'portfolio_page' );
$title = __( 'Back to Portfolio', TPL_SLUG );
else{
$href = site_url() . '?page_id=' . get_option( 'page_for_posts');
$title = __( 'Back to Blog', TPL_SLUG );
if( defined( 'PORTFOLIO_PAGE' ) && PORTFOLIO_PAGE ){With regards.$href = home_url() . '?page_id=' . $this->get_option( 'portfolio_options', 'portfolio_page' );
else{
$href = home_url() . '?page_id=' . get_option( 'page_for_posts');
Thank you!
