Language Switcher (WPML) Problem RifePro
in FatMoon Posts: 304
Hi Air
I'm translating a website already done using wpml and I'm having weird behaviors in the menu .. when using the language switcher from wpml I get duplicate entries in the menu! If I set the wpml language switcher not to use anything in the menu I have both languages showing .. is there a conflict beweent Rife and WPML or did I not unterstand something? All I need is the language switch for the the language not shown (no need for current language).. can help?
You can see it here: https://ml.lunique-foundation.org/support
Thanks, Pascal
    almost forgot: also the header behave differently when I switch language...
    FLYART said: also the header behave differently when I switch language...
    You have different header color varaint set in this page in the German language(normal variant). In English you have dark variant.
    FLYART said: when using the language switcher from wpml I get duplicate entries in the menu! If I set the wpml language switcher not to use anything in the menu I have both languages showing .. is there a conflict beweent Rife and WPML or did I not unterstand something? All I need is the language switch for the the language not shown (no need for current language)..
    I don't know about any conflict. So what options you have used to activate the language switcher?
    Hi Air
    Thans for your fast reply! To activate the language switch I simply used the wpml language switcher option (see screenshot). When I use it (like I did now for you to see) it doubles the language option in the menu (so now I have german twice).. if I add current languae I have current language twice... no clue where ohter settings might be?
    Thanks for the header info.. seems like dupicationg the page in wmpl doesn't automatically use the same header choice?
    Thanks, Pascal
    1096 x 882 - 102K
    FLYART said: Thanks for the header info.. seems like dupicationg the page in wmpl doesn't automatically use the same header choice?
    Hard to say what is happening on this action. WPML developer would have to speak.
    FLYART said: if I add current languae I have current language twice... no clue where ohter settings might be?
    I will check tomorrow what could be going on. There are just too many variables to guess what is the correct solution.
    With kind regrads.
    Just sent you the info.. thanks for your help!
    Pascal
    It seems there is indeed some kind of "conflict" with a new version of WPML, as WPML has introduced new features for language switchers.
    To fix it I have removed below code from rife\advance\utilities\wpml.php line ~10
    //we are removing default filter for language switcher and alter it a bit
    if(!empty($sitepress_settings['display_ls_in_menu']) && ( !function_exists( 'wpml_home_url_ls_hide_check' ) || !wpml_home_url_ls_hide_check() ) ) {
    	remove_filter( 'wp_nav_menu_items', array( $icl_language_switcher, 'wp_nav_menu_items_filter' ), 10 );
    	add_filter( 'wp_nav_menu_items', 'apollo13framework_wpml_add_custom_menu', 10, 2 );
    In my opinion, this code is still valid when you want to have language switcher as a submenu, but I will have to revisit it for the new version of WPML.
    Thanks for your help!
    Hey Air
    Wow, thanks.. never would have thought it's that "deep"! Great it works for now and sorry you'll have to revisit the new wpml feature for the rife implementation!
    Have a great day!
    Pascal
    Thanks, Pascal. WordPress is changing every day;-)
    Have a great day as well my man!
    Hi again Air!
    I have a question that is tottaly out of support range! But if you might have a "second" to look at it it might help?
    I am having a weird issue with languages in the give forms. I am using two different forms (one in english one in german). So far so good. In german when opening the form everything is in german until I change the payment method using the radio button then parts of the form appear in english. From that moment these fields remain in english even when switching back and forth..
    https://ml.lunique-foundation.org/spenden/?lang=de
    I totally understand if you don't have the time or if it's out of scope.. no worries.. I still love you if you can't help me :smiley:
    Pascal
    1417 x 842 - 153K
    I believe this is a bug. It probably doesn't send language parameter when requesting update form, and you get wrong localization. Just guessing.
    You should talk to authors of these plugins, sorry :-)
    Just what I thought .. and of course I already did post in WordPress Support for this.. but you guys are good and fast so I took a shot at it ;)
    Thanks, Pascal
    Hi Air
    Remember the above problem I had with the language switcher (as you helped me in php above) .. well.. updating to WP 5.1.1 created a similar problem.. and I cannot find that part in the mentionned php file (maybe I'm just stupid :)) .. can you help?
    Thanks, Pascal
    1034 x 569 - 857K
    Could you please send me temporary* access to your WordPress and FTP so I could check there what is going on? Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
    Hi Air
    Thanks for your help.. I sent everything thorugh private message
    Link is: https://lunique-foundation.org/wp-admin
    Fixed :-)
    The code was in line 10 of the mentioned file.
    Thanks a lot.. how could I not see that????
