Albums Categories in WP admin panel
edited January 2020 in PhotoProof Posts: 96
Hi!
Happy New Year first of all!
I'm trying to understand the need of "Albums Categories" within the WP admin panel.
PhotoProof comes with Gallery, Scroller and Slideshow. I've tried to understand the feature, but I'm not sure if I did. Is that to filter within the general overview of all my albums (in case I would use such an overview eventually)?
This question came up, as Google crawled such categories and now displays me at some of its search results output entries nonsense, as I haven't used that feature since today on my site.
For instance I haven't created this page:
https://lange-grumfeld.photo/de/genre/scroller-de/
I've flagged the 'album categories' to 'draft' now and added via Yoast SEO, that this page shouldn't be crawled. Nevertheless upon clicking the Google result, the page is loaded. I would have expected it's now receiving a 404, shouldn't it?
Thanks for bringing in some light.
PS: Addition. Found an option in Yoast SEO to deactivate album categories in search engine. However, given the other problem with the credential page (see my other thread), Yoast SEO needs to be deactivated during normal operational, which means this feature isn't available. May I instead delete the album categories instead?
Post edited by MLG76 on
    MLG76 said: Is that to filter within the general overview of all my albums (in case I would use such an overview eventually)?
    Yes, like here for example https://rifetheme.com/cropps/albums/
    MLG76 said: I've flagged the 'album categories' to 'draft' now and added via Yoast SEO, that this page shouldn't be crawled. Nevertheless upon clicking the Google result, the page is loaded. I would have expected it's now receiving a 404, shouldn't it?
    For me it is 404. If you are logged in you will see this page even if it is draft.
    MLG76 said: May I instead delete the album categories instead?
    You don't have to use Album categories at all. Just delete all the categories :-)
    Hi Air,
    Thanks. Understood. Great!
    Yepp, was impatient yesterday and went the risky way and deleted it.
    Now things are fine.
    Thanks for clarifying.
