I have a problem with albums: in each and every template I try to edit an album, the buttons are not responding. No matter whether I click "X" on the photo or the "pencil" button or try to change the order, not to mention trying to add new pictures. Am I missing something?
I suspect you are facing some JavaScript error, and that is why API is frozen.
Could you try to disable all plugins, except for "Apollo13 Framework Extensions" and check if it will work then?
basicaly the only thing I can do is edit the text. The rest is not responsding.
I can't make any slidebar at the moment, I tried WORKS and it.. works ;p
Media works fine as well, it seems only ALBUMS does not react to clicking buttons there when editing any album inside. There is no popup window where I can select media I would like to add and it also doesnt react when I try to interact with already existing media like pressing the edit or X button or trying to change the order.
I'm stuck and cannot finish my new project as I wanted to put slider on the top of the page
It turns out that on your server you have it configured in such a way that In PHP decimal numbers are converted from dot-separated to comma-separted.
This results in the number being converted from "0.1" to "0,1" and this crashes JavaScript later on.
I have made a few changes in the theme code on your server, and the same changes I will add in the next theme update.
Anyway, now albums are working fine.
Thanks once again!
I'm glad I could help find and solve some bugs for the rest of the community
Thank you kindly for help of course !
