Rife pro theme - position of bricks filter
Hi. Is it possible to adjust the position of the brick filter so that it appears immediately over bricks? In my case the desktop is fine but the mobile version retains the filter above the text and not above the images, where we need it. This is Because the content is responsive and stacks on a mobile.
Thank you
  • You would have to show me the exact page that presents this issue and I will be able to give you exact response.
    Support, The
  • Hi, Thank you.
    We wish to change position of the bricks filter so it appears immediately above the images in a responsive stacked mobile view (see image 1) OR at the bottom of the images bricks between the brick and the footer. (see image 2)
    Thank you
    1024 x 1524 - 1M
    1010 x 1501 - 2M
  • But there's no filter at the moment.
    Support, The
  • There is no filter, because we will only enable it if we can locate the filter menu at the top of the bricks. can we have direction as to how we can change position from top of album to top of bricks? This would mean that on a mobile screen, the text content comes first and then the filter and then the bricks (images).
    Thank you
  • OK, but this page is not a Album List page, it's an Single Album.
    You can't have a filter for single album, you can have a album navigation.
    Support, The
  • Is it possible to locate the single album navigation between at the top of the bricks, not the top of the album?
    We have content enabled on the left hand side and wish the single album navigation to be located after the text in the content but before the bricks.
    Thank you
  • I must apologize.
    There's a way to use a top filter for single album.
    Yellow - album filter
    Green - album navigation.
    To enable the Filter you need to assign a Tag for each image within the album. You can do it by editing Album Item: https://rifetheme.com/help/docs/content-management/albums-works-post-types/album-media/
    For Album Navigation manipulation you need to go here: Customizing ▸ Albums settings ▸ Single album and change 'Albums navigation' option.
    1454 x 774 - 573K
    Support, The
  • Thanks. And when this ‘stacks’ on a mobile the filter is first then the content text comes after then the bricks. So our question is, can the filter be between the text and the bricks. Ie- appear always above the bricks and not top of the page.
  • No, at this moment, it's impossible.
    But I will add this to the development roadmap as well.
    Support, The
  • ok. thanks
