Menu is list, not inline and can't view shortcode field
edited March 2013 in Skyfashion Posts: 3
I just purchased, installed and configured Skyfashion theme.
Webpage is online at: http://www.dotyouri.it
1)As you can see, main top menu is not inline as the bottom one is.
2) In the control panel, I can't see the "Airlock shortcodes" field, nor in the "New post" or in the "New page" (see attached screenshot)
I am using Wordpress 5.3.1, with italian translation.
Please help with these problems, I can provide administration access.
Thanks in advance
  • Hi,
    1) have you mange to fix ti? I can see this problem. What browser do you use?
    2) There should be green plus sign in the toolbar in the postedit page. Do you have it?
    Best,
    Miłosz
  • Hi Miłosz,
    1) I didn't try any fix, because I got this bug just after a fresh install of both Wordpress and the template; I didn't have enough time to investigate, sorry
    2) I found it, thanks!
    I am using Chrome but I see problem number 1) even using Explorer and Firefox.
  • Hi,
    I fixed menu inline problem, adding following custom css rules to style-light.css:
    #menu-dot-your-i-1{
    display: inline;
    #menu-dot-your-i-1 li{
    display: inline;
    margin: 15px;
    #menu{
    line-height: 24px !important;
  • Hi,
    good to hear it.
    If you have any problem, please ask.
    Best,
    Miłosz
