Background gallery
edited April 2013 in Skyfashion Posts: 7
I would like to know how can I change color and opacity background when I press and see the image. At this moment the background is dark but I still see the main site below. I would like to have for example just black background.
My website http://patrykstanisz.co.uk/
And second question: Is somewhere option to set " open link in new window " for positions from Menu?
Thanks for help
Regards
Patryk
  • Hi,
    you need to edit Fluxbox css file to change it. There is set background color.
    You need to add target="_blank" in the generating menu script.
    Best,
    Miłosz
  • edited April 2013 Posts: 7
    Thanks for reply.
    Could you tell me where should be Fluxbox css file? I can't find it.
    I can't add < a href = "website link"target="_blank">Blog< /a > as name in menu. When I do it and trying save it then the link name disappeared. Of course there is no space between "<" and "a"
    Post edited by Patryk on
  • Hi,
    sorry, my bad. The script's name is Fancybox. Css file is in the css folder.
    I see you have manged to add Blog name to menu, right?
    Best,
    Miłosz
    Yes, but still the link is not opening in new window. Where I should add target="_blank" in menu script?
    Regards
    Patryk
    I have decided install Nextgen Gallery and plugin lightbox 2. I have 2 new problems. First. There is all time menu on top when I press on the picture. For example here: http://patrykstanisz.co.uk/portrait-photography/?show=gallery
    2 problem.
    When I watch by ipad the right part of picture is cutting. The website is a little bit short from right side.
    Thanks for help to solve this problems.
    Patryk
    P.S. If you are from Poland, you can write in polish language ;)
  • Cześć,
    masz zainstalowaną najnowszą wersję naszego szablonu?
    Jeśli tak to będę musiał dokonać zmian w kodzie, więc dobrze by było gdybyś przesłał mi swój login i hasło na support@apollo13.eu.
    Co do drugiej sprawy, mógłbyś przesłać mi na email screen?
    Miłosz
    Please write in English, this international forum!
    Thanks with regards.
    I have sent login and password. Let me know whether you got mail.
    Regards
    Patryk
