Text not in right position
edited December 2011 in Airlock Posts: 5
Hi there,
I have a problem with the horizontal position of the »categories«, called »Seiten« in german. Illustration enclosed. Anyone an idea?
(I am yet working on Umlauts in the cufon thing, but I will succeed, so thanks for that so far.)
Thank you,
penalty
Airlock 1.4
easy-theme-and-plugin-upgrades.1.0.1.
Mac OS X 10.4
Firefox 3.5.19
Wordpress, deu, 3.3
    Please provide link cause this image tells almost nothing. Thank you :-)
    I see, something with menu seetings in your wordpress.
    Your div#menu don't have ul.menu inside but only simple 'ul'.
    Maybe some plugin, can't tell.
  • There are no other Plugins installed then Easy Theme and Plugin Upgrades and WordPress Importer.
    How can we fix this Problem? In which CSS-File can we find div#menu?
    Thank you for answer!
  • Additionally the Menu doesn't work really...
    Go to www.ugcd.de and then test "Referenzen" and "Aktuelles"
    Thank you.
  • I found it!
    You have to delete the Menu at "Design - Menues" and make a new one. Then the bug doesn't appear any more.
    Nice! Thanks for sharing all info. Sorry for small help in it.
