Hello. I tried to found the answer in the forum but i did not find it.
I would like to replace the little circles (how appears depending the number of pics) with only 2 arrows (next - pre).
How can i do it ?
www.n-e-t-e.com
thanks a lot for your help.
Jorge
Go to file
airlock\common\js\scripts.jsline ~266 and change to: Don't worry about white spacesNext unpack this ZIP file that I have attached and copy whole directory images to
airlock\common\and then you will see arrows.With regards.
Thanks a lot
Regards from Nîmes in the south of France
Have a nice day and If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks!
