Code for "Show Info" to display a picture and text (like the Live Preview) vs the default Google Map
edited January 2013 in Hypershot Posts: 8
Hello, sorry for this basic HTML question. I would like to change the Show Info section to display a picture and some text as it is shown in the Live Preview. Right now, the theme options show code for a Google Map.
Thank you!
    This is HTML from our demo, sorry for not including it in public version:
    <img class=" alignleft" src="http://themes.apollo13.eu/spaceship/wp-content/uploads/2012/07/061-300x300.jpg" alt="" width="150" height="150" />
    Lorem ipsum dolor sit amet, consectetur adipiscing elit. Maecenas iaculis, felis vel adipiscing sollicitudin, urna nisi porta dui, in hendrerit sem nisl sed lectus. In felis ante, fermentum malesuada venenatis id, laoreet eget mi. Duis non justo in lorem rhoncus sodales. Vivamus sit amet lorem nulla. Pellentesque non quam quis sem accumsan ullamcorper. <br /><br />
  • Thank you!
    Hi Air,
    I think my question fits here... Please let me know if I should create a separate thread in the future.
    Could you please send me the html code for the Google Map? I'm having problems finding the right plugin to work with the theme so I'll just use what you had in the installation file. The thing is that I already deleted it a long time ago. :S
    LazyDiver
    Hello
    Go to Google maps, find your place and then you can get HTML to put in your site.
    http://designshack.net/articles/html/embedding-google-maps-into-a-web-page-a-beginners-guide/
    Hi Air,
    It works when you put it in the Show Info/header, but it doesn't work when you insert it into a post. Is it because it conflicts with the Simple Google Map plugin? Or am I doing something wrong?
    Here's the screenshot: http://imgur.com/eJdwkZT.
    Thanks.
    Probably Wordpress editor is removing every iframe, as it is potentially dangerous. You will have to either read about how to enable iframes in your editor or find some plugin with shortcode for it.
