section "Latest works" in home page for some browsers is shown on two lines insted only one as usual. Problem is there only for some browser like IE 9 or Firefox 25 for example.
In attachment you can see a screen-shot for the problem that affects also your template demo page.
Could you please help me to find a way to show "Latest works" section on only one row?
Many thanks for the support,
VIA Art Project
Many thanks,
VIA Art Project
Could you send me a link to your webpaage?
Kind regards
I wrote you a private message with all details.
Many thanks,
VIA Art Project
Ive got your priv msg. Could you send me temporary login data to your wordpress too? I will check your internal configuration ASAP.
Kind regards
Many thanks,
VIA Art Project
I sent you prv msg with resolved problem.
Kind regard
Thx !!
sangana
Its true
Find div.slide_box in file common/css/layout.css and add a property like that:
div.slide_box {
... (code which is in file)...
float: left;
Kind regards
Thx again !
Regards.
