first, I know this theme is actually unsupported, but after days of desperation I have to ask for help, if staff can't, may be oher users.
I reinstalled skyfashion (after a hosting change), and my selected font "Oswald Light" is not showing in "Latest Blog Posts" Anyone knows how to correct it?Iin others tittles is OK. I fixed it first time i installed but cant remember how and can't find the post that helped my that time.
Thanks in advance.
Please post live link to page where problem occurs.
The site is www.stylecoach.es
Thanks you Air
I don't see where this font don't show up. All titles are ok. Can you show on screen shot which part you mean?
I don't have access to Skyfashion so I don't know how panel works there but I can see in your page that you have such style added And this breaks your font in post titles. If you added this by yourself then remove part
, .latest_blog_post_topicWith regards.
I did not added that and can't find the code written in that way in any document, so I give up
Thanks again
body h3.latest_blog_post_topic {With regards.font-family: 'Oswald' !important;
I tried before, but I forget the "body h3."
One thousand thanks.
