I just bought your awesome theme and wondered if there is a way to replace icon in the menu by a image file (png or jpg).
if by that way i could add some code instead of the name of the icon in the page "menu icon" field... that would be nice !
i already checked the forum and i didn't find antyhing to guide me.
Thank you again for that theme.
Regards from a small french island called Reunion Island.
Olivier.
Go to advance/utilities.php line ~752 and remove this: or in some case it can be better to change above code to: With regards.
actually i found a greater solution... i just turned my png file in .svg format (exporting from illustrator), so my png become a font, and i can call it from each page.
It's very nice this way, as soon as my site is ready, i'll share it on the topic "show your beach"
I have an other request !
Concerning "my works" edit possibilities... would it be possible to put an icon in the custom info 1, custon info 2....
actually i'd like to put an icon and some pdf file to be downloaded.
i'm not so friendly with custom field management...
Thank you for your support !
That is great how you solved this:-)
It would be nice if you would start new topic for your new question. Why? Read more here. Meanwhile I will think about answer for you.
--EDIT
Answer: So all of this you can do currently: just insert such code in your custom info field to see results:
<i class="fa fa-medkit"></i> : http://apollo13.euWith regards.
