I promise this is my last post for today.
I guess everything is in the title : is it possible to open link in a new tab or window ?
i'm talking about links in meta fields on work page, and also alternative links on galleries.
If it needs to add some _target blank in the code, please tell me where !
Than i hope i won't have to ask you anything, i don't want to abuse on your nice support!!
Meta fileds:
file single-work.php, line 58 Instead of
make_clickableyou will have to use own code.Galleries:
file galleires-list.php, line 103 You will have to detect if alternative link is used and add your param then.
this is the working code in single-work.php on line 58 : and the one for the galleries-list.php on line 103:
Advice for people who's using thoses codes : don't forget to save thos files in case of update, and check the changelog !
Thanks a lot !
You can copy changed template to child theme and it will be used instead. Of course if you use child theme.
